Motor: None :-)
Växellåda: TH700
Färg: Vit
Kaross: Glastarga
Inredning: Ventura Skinnklädsel (Camel)
Instrumentering: Analoga mätare
Fälgar: Rondell NR 57
Däck: 265/35/18 Bak: 235/23/18 Fram
Övrigt:
Motor: Nope :-)
Transmission
- Växellåda: TH700
- Superior shiftkit
- B&M kylare
- B&M Torkmaster 2400rpm converter
- Förstärkt växellådsfäste poly
Shassie:
- Hotchicks Subframe Connectors
- Tokiko High-Performance Series Shock,Front
- BMR Steering Support Brace
- BMR Lower Control Arms Tubular w/ Poly/Poly Bushings
- BMR Fabrication Anti-Squat Brackets, Bolt-In
- Eibach Sport-Line Springs, 1.6" Drop Front & 1.3" Drop Rear
- BMR Panhard Rod, Adjustable w/ Poly/Poly Bushings
- Poly bussningar i länkarmar fram
Interiör:
- Auto Meter Ultra-Lite, Oil Tempature, 100-250 degreesF, 2 1/16 in,
- Auto Meter Ultra-Lite, Transmission Tempature, 100-250 degreesF, 2 1/16 in,
- Auto Meter Ultra-Lite, Air/Fuel Ratio, Lean/Rich, 2 1/16 in
- Auto Meter Sport-Comp Silver, 10,000 RPM Monster Tachometer, 5 in with Amber shift lite
För mer info se under tråd Projekt Uppgradering 350 till 383 !
http://www.tacs.nu/forum/viewtopic.php?t=8472
Medlem 389 - Pontiac Trans Am GTA -90
