Medlem 236 - Pontiac Trans Am -84
Här kan tacs medlemmar skriva text och lägga in bilder på sina Pontiacar och övriga titta på dom. Det går inte att svara på inlägg här detta för att man själv skall kunna uppdatera informationen om bilen, eller ta bort den om man sålt sin bil.
v8guy
Inlägg av v8guy »
Color: Yellow (original was Black and Gold).
Type: Targa
Engine block: SBC 350 (+.030)
Heads: GM 441 HomePorted
Camshaft: Edelbrock, secret values
Intake: Edelbrock Victor Jr, Converted to EFI by Aldengard Engineering
Plenum: Custom made, Designed by Aldengard Engineering
Throttle Bodies: 2xVolvo 850 55mm Throttle Bodies - kind of small but makes the engine react fast when throttled.
Exhaust manifolds: Made for 2 Garret T04, design/product of Aldengard Engineering
Exhaust: 3" Custom Made Stainless CatBack by Aldengad Engineering. Loud but polished.
Intake duct: Design/Product of Aldengard Engineering
Air filter: 2 x K&N Cylinder shaped (3" outlet)
Turbos: Garret T04E
Wastegates: 2 x Rosenkrantz (52mm).
DumpValve: 1 x Rosenkrantz (50 mm).
Current boost level: (first run, 0.65 bar)
Intercooler: KL-Racing, 77x30x10 cm. 3" connections.
Transmission: Borg Warner T5 (stick shift)
Flywheel: Hays steel flywheel (still not lightened)
Rims: BMW 5-series, 17x8 front, 17x9 back.
Wheels: Some sticky brand...
Brakes front: C o r v e t t e C5 discbrake rotors, Trans Am 98+ Brake Calipers. Adapters by Aldengard Engineering.
Brakes Rear: Stock, will be replace with calipers and rotors from Trans Am -96. (PBR calipers).
Chassie:
Subframe connectors: Global West
Wonder bar: Made by Aldengard Engineering
Bushings: Polyurethane on all parts.
Panhard bar: Founders Performance
LCA: Founders Performance
LCA Relocation brackets: Founders Performance
Front caster/camber plates: Founders Performance
Injection system:
Computer: MegaSquirt EFI v2.2 with "MegaSquirt n Spark Extra firmware", release "extra024S9".
Lambda: Wideband Lambda, not only used for tuning, it's connected to MegaSquirt all the time and part of the control system.
Fuel: E85 and Unleaded 98 octane gasoline.
Fuel system: Single Bosch 044 pump, will add a second one and 15mm fuellines.
Injectors: 1200 cc.
Ignition: Aftermarket HEI (replaced the old pretronix converted one).
Coil:HEI
Sparkplug wires: Red and thick ones.
Sparkplugs: NGK ??.??
Interior Modifications:
Gauge pod pillar: For the A-pillar, 3 gauges.
Gauge: Autometer 52mm Ultralite Boost
Gauge: KL-Racing oiltemperature
Gauge: KL-Racing water temperature
Gauge: Digital Wideband Lambda
Stereo: 2DIN stereo mounted via a watercut aluminum plate, design Aldengad Engineering.
Planned modifications:
Ignition: GM HEI 7-pin module controlled by MegaSquirt.
Boost Control: Volvo or SAAB boost control valve, controlled by MegaSquirt.
Shift Light: Controlled by MegaSquirt.
Safety: 5 point seat belts.
Cooling: 19 row oilcooler - bought but not installed yet.
Lighter parts: Fiberglass Hood, design/product of Aldengard Engineering.
Lightweight Race seats
Installation of my modified T56 Transmission.
